Tire Size
Tire Size
I have a GS3 (2001) with 215/60/16 as summer tires.
I just put on a set of 225/55/16 blizzak's.
Does the different tire size effect the speedo and the Odo??
Maybe it's just me, but I seem to be going slower than what the speedo says.
Yeah I think you just have to get use to the low profile tire. there use to be a link here where you could put in your new tire size and it would tell you that type of info. Does anyone have that link......
Speedo
David - Your speedometer reads off your ABS sensors on the wheels so as long as U don't drastically deviate from the factory overall tire diameter, things will remain accurate. FYI - the stock 215/60/16's have a diameter of roughly 25.2" while the 225/55/16 combo U R using now show to be 25.0". Not enough difference here to matter, IMHO. Enjoy the ( hopefully ) better traction of the Blizzaks this winter!!
Speedo site and Calculations
As Mean Gene says...not much difference. Speedo will read 1.6% too fast. So when it reads 60, you are really travelling at 59.1 mph.
Here's the site http://www.miata.net/garage/tirecalc.html
Re: Speedo site and Calculations
tires and speedometer
For what it is worth, I saw an article somewhere that had compared speedo error among cars, and the Lexus GS4 with stock 225/55/16 wheels was reading about 1 mph fast. I think the nominal o.d. for this tire would be 25.74, so you could compare using nominal o.d. for other tires.
You can check it using the mile markers alongside the highway. Set the car right on 60 mph and time from one mile marker to the next. If it takes 59 seconds, your speedo is reading 1 mph fast. If it takes 61 seconds, it is 1 mph slow. This will work ok up to 2-3 mph error.
Lexus Dealership
I also noticed that based on the stock size 215/60/16 tire, both 225/55/16 and 235/45/17 tire are not as closely matched as you think...Observe:
Specification Sidewall Radius Diameter Circumference Revolutions Difference
215/60-16-------5.1 in---13.1 in--26.2 in----82.2 in-------771 / mile--- N/A
225/55-16-------4.9 in---12.9 in--25.7 in----80.9 in-------783 / mile--- -1.6%
225/50-17-------4.4 in---12.9 in--25.9 in----81.2 in-------780 / mile--- -1.1%
245/50-17-------4.8 in---13.3 in--26.6 in----83.7 in-------757 / mile--- 1.9%
235/45-17-------4.2 in---12.7 in--25.3 in----79.6 in-------796 / mile--- -3.2%
245/45-17-------4.3 in---12.8 in--25.7 in----80.7 in-------785 / mile--- -1.8%
255/45-17-------4.5 in---13.0 in--26.0 in----81.8 in-------775 / mile--- -0.5%
Ed
Ed
