Re-Lipping rims, am I measuring right?
Heres me measuring.
![](http://i45.tinypic.com/1jxogw.jpg)
My rears a 3 inch lip so I assume? The whole rim is a 20x10, so that leaves the inner barrel as a 7inch and lip as 3 inch?
![](http://i49.tinypic.com/143euqq.jpg)
same measurement different angle.
So if I wanted a 20x11.5 I would have to buy 4.5 inch lips? It all seems too simple too me..
It's difficult to say how the manufacturers measure their barrels. I'd say the more technical way to measure would be to have your multi-piece wheel disassembled and measure from the mounting flange to the face of the lip. That should give you the correct overall width of the outer lip.
That doesn't mean what you're doing is wrong. Your manufacturer could use your measurements and figure out the correct width through their specs. Lastly, I'm sure you've given some thoughts about your offsets? Since you're only changing the outer barrel, the extra width is going to push outwards.
Former Sponsor
No your not. To get the correct measurement , the tire should be off or the wheel should be taken apart. Can you give me more information?
Brand of Wheels :
Sizes /Widths:
What year make and Model of your car:
Brand of Wheels :
Sizes /Widths:
crimson japan
fronts 20x9 (40 offset) 2 inch lip
rears 20x10 (38 offset) 3 inch lip
04 g35 coupe , picked up the rims from someone on the forum here.
Yea making sure the wheels lips are true to size you should take out the faces and measure from the flange of the putter shell nothing more true than that.
Carlos Castellano
Kartel Forged
PH:305-733-9064
Email: kartelforged@live.com
Www.facebook.com/kartelforged
"The Perfection of Stance & Luxury"
Carlos Castellano
Kartel Forged
PH:305-733-9064
jesse gs30
03-03-10 11:26 PM
