Off-set questions
Old 11-24-13, 07:33 AM
laopadak
laopadak's Avatar
Default Off-set questions
09' isf with stock wheels. Stock wheels are F- 19x8 +45, R- 19x9 +55
I'm running 15mm spacers up front, 20mm spacers in rear (bought car like this, H&R with longer wheel bolt studs)
What would my current offset be?
Would I subtract or add the wheel spacer thickness?
In the market for a nice set of aftermarket wheels, most that I've seen don't have the high offset recommended for the F. I don't want to remove the extended studs / spacers if I don't have too.
What would be a good offset, F&R on an aftermarket set that I could run with with the spacers and extended bolts? Ideally the total offset would be close to the recommended offset.
Thanks in advance for any solid advice.
Old 11-25-13, 03:30 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Your current offsets are +30 front and +35 rear, you subtract the spacer from a positive offset wheel...
Those are very popular offsets, only reason you'd need to remove spacers is if you also wanted wider wheels...
Old 11-25-13, 02:24 PM
laopadak
laopadak's Avatar
Thanks for the response mitsuguy.
So if I go aftermarket, keep the spacers / extended studs, I'd need a similar to stock offset for my aftermarket wheels so to maintain my current stance.
If I remove the spacers then a +30 F and +35 R offset will give me the same stance.
If this is correct then my options on preowned wheels opens up quite a bit. Just have to remove the spacers and extended studs.
Old 11-26-13, 12:45 AM
mitsuguy
mitsuguy's Avatar
You got it!!!
pkjai
IS - 1st Gen (2001-2005)
08-19-12 08:05 AM
Pearl250
05-06-10 07:45 PM
350nub
08-27-08 01:23 PM
SPEED&ECO.
05-13-07 12:01 PM
Okay
01-12-07 09:30 PM
Quick Reply: Off-set questions
