Recommended tire pressure for 245/35/20 and 275/30/20
Old 01-25-03, 07:43 PM
GS4ADRLexo
GS4ADRLexo's Avatar
Default Recommended tire pressure for 245/35/20 and 275/30/20
I just realized that I have not checked my tire pressure AT ALL since i got my rims put on about a month ago, so I was wondering what tire pressure is recommended for my setup. I have 20x8.5 up front on 245/35's and 20x10 out back on 275/30's. Last night I was having a little bit of tramlining occuring, so I'm thinkin that I need to check the tire pressure. Any input is appreciated! Thanks!
Old 01-25-03, 07:48 PM
GS4ADRLexo
GS4ADRLexo's Avatar
I just checked to see what my current pressure is...it's between 34 and 36 psi on all four tires; if anything this seems HIGH to me.
Old 01-25-03, 07:54 PM
bravo261
bravo261's Avatar
those are the tires i got and i run about 38psi, the same number i've seen around here
Old 01-25-03, 08:25 PM
GS4Will
GS4Will's Avatar
G,
one of the key factor that will help preventing wheel bent is enough pressure in the tyres..37-40 psi(cold tyre) is ideal
Old 01-25-03, 10:25 PM
Kajukenbo
Kajukenbo's Avatar
Air in your tire is the only thing that probably will save you from bending that lips when hitting a pot hole, especially with low profile tires........
I need to make a mental note to myself too!
Old 01-25-03, 10:36 PM
mjames08
mjames08's Avatar
I ran my 245/35/20's at 40psi..
Old 01-26-03, 11:56 PM
MrSypher
MrSypher's Avatar
Me too.....
hube
09-26-15 11:17 PM
ShawnOk
04-18-15 12:13 PM
Rezaxxed
12-15-08 10:12 PM
Hartawan
12
04-02-08 01:41 PM
Ozzy
04-01-08 07:06 PM
Quick Reply: Recommended tire pressure for 245/35/20 and 275/30/20
