Tires Rotations X rotate?
Old 01-29-03, 02:01 PM
Gs400TRD
Gs400TRD's Avatar
Default Tires Rotations X rotate?
Is there any tire out there at can be used with the stock 17" that can be cross-rotated? I have the inner front tire wear problem too and the dealer made it worse after the alignment...go figure.
What I did as a temporary fix was to remount and swap tires side to side, then front to back. So the inner are the outer and vise versa. It would be much easier to "evenly" wear the tires if they can be cross-rotated. I don't mind giving up some performance since I have a performance car in the garage for those days when I need to let out a bit more steam.
Thanks.
Old 01-29-03, 05:30 PM
rominl
exclusive matchup
rominl's Avatar
yeah if the tires are not directional. but all performance tires are directional so you will have to unmount them
Old 01-29-03, 07:48 PM
mooretorque
mooretorque's Avatar
Talking
Directional tires are that way primarily for wet traction; reversing the pattern would, I think, be hazardous in rainy weather, since water would tend to be pushed back in front of the tire.
Old 01-29-03, 10:22 PM
Gs400TRD
Gs400TRD's Avatar
I guess I need to clarify my question.
I wanted to know if there are any brands of tires they sell that will fit a stock gs400 that are not directional?
Like what is available on the factory 16" tires.
Thanks.
Old 01-29-03, 10:34 PM
pcmw
pcmw's Avatar
Gs400TRD,
Forgive me for being obvious. But X - Rotating your tires will still leave the inside on the INSIDE.
MW
Old 01-29-03, 10:44 PM
Gs400TRD
Gs400TRD's Avatar
DOH!!!
I feel like homer.
Ok I need wheels that can be tightened from both side and some wild wheel spacer
So the only way is to basically dismount remount
Or find someone that can fix the da#@$@$ Alignment problem!!!
Old 01-31-03, 08:18 AM
kvoman
kvoman's Avatar
Yes, the BFG g-Force KDWS (Z-rated). That's one of the reasons why we bought them. They are non-directional and can be rotated front to back, x-direction, or whichever direction you want.
We have the stock 235/45/17 tires.
ilen
RC F (2015-present)
20
01-20-22 02:37 AM
Oreo27g
03-30-10 07:53 AM
kloh7
01-31-07 01:47 PM
1NICESC430
05-14-03 02:47 PM
XTC
SC- 1st Gen (1992-2000)
13
02-16-02 08:47 PM
Quick Reply: Tires Rotations X rotate?
