Is it rotors or another problem?
Old 08-13-14, 01:42 PM
Slvr surfr
Slvr surfr's Avatar
Default Is it rotors or another problem?
Last year i replaced both front rotors on my 05 LS. For the past 4mos ive been having a shutter/shake when apply the brakes lightly but when i press them hard or quickly slow down from a high speed there is no noticeable shake. I inspected the pads and rotors which seem to be ok visually. I do hear a light scraping noise when driving without the pedal depressed and some creaking noise when i do hit the brakes. Could my rotors be bad again only after a year and a half? Sticking/stuck caliper? Any other ideas before i start tossing money in? Mileage is 157k.
Old 08-13-14, 08:04 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
sounds like it could be a rear if you only feel it in the pedal...
Old 08-13-14, 10:09 PM
Slvr surfr
Slvr surfr's Avatar
a
Actually I dont feel it in the brake at all. Only the steering wheel vibrates. Also the shake varies from moderate to heavy depending on heat I think.
Slvr surfr
08-15-14 07:26 PM
JDMis350
10-07-12 12:54 PM
DaytonaSTi
06-17-10 02:30 PM
truenoboy
Suspension and Brakes
06-30-09 09:02 PM
DaJark
10-16-06 06:16 PM
Quick Reply: Is it rotors or another problem?
