seen the new lowenharts?
I know Dazz is a distrubutor fir the US, what I meant was all the wheels that they sell look alike....Lowenhart, Maya, Maido etc.
Check these Maido wheels
These remind of BR5's
These look exactly like L-Sportlines that they also sell
MD1's ha....even the names are similar
![](http://www.maidowheels.com/wheels/9.jpg)
![](http://www.maidowheels.com/wheels/4.jpg)
![](http://www.maidowheels.com/wheels/1.jpg)
Does anyone know if there are Lowenheart LT6 or Maya TTS wheels that fit on the GX70 SUV? I have been trying to find some deep-dish, 5 or 6 spoke, chrome wheels between 20" to 23" but none fit properly. The problem isn't the 6-lugs or the offset, it is the round nipple in the middle of the offest on the vehicle. Apparantly, it is 110mm and is too large for most wheels as the bore in the aftermarket wheels are too small. We tried some wheels and 23"" isn't a problem either. I had 23" lexani VP wheels on the car but since the bore hole in the wheel was slightly smaller than the car's nipple, the wheel was not bolted perfectly against a flat surface. This causes balance problems at certain speeds. Using a spacer sounds like it would solve the problem but it still had balancing vibrations.
So, who makes wheels that fit the GX470?
Craig
Craig
I think those LDRs look TERRIBLE on that SL. They might look better on something bigger/taller though, maybe an S class.
