URGENT - Will 18x8.5 wheels with 35+ offset fit the IS300??
Old 04-24-03, 11:26 AM
lil' IS300
lil' IS300's Avatar
Exclamation URGENT - Will 18x8.5 wheels with 35+ offset fit the IS300??
I bought some new rims 18x8.5 with 35+ offset for the IS300, and I was told these would fit. It's only now that I was told it probably won't. So I want to know, will these fit the IS300?
If not, can I modify to do so? Shave/roll fendors?....anything?
Old 04-24-03, 12:23 PM
rominl
exclusive matchup
rominl's Avatar
Default Re: URGENT - Will 18x8.5 wheels with 35+ offset fit the IS300??
18x8.5 all around? if so, you will rub very bad in the front. it's just way too wide. even with 18x8 you should stay +42 or higher i believe. rolling and shaving won't help i guess
Old 04-24-03, 02:16 PM
lil' IS300
lil' IS300's Avatar
What if I use spacers? Would that help, or no?
If these rims don't fit, it looks like i'm going to be selling them...
Old 04-24-03, 03:21 PM
lunatictokyo
lunatictokyo's Avatar
not even close unless you pull the fender or get a fender kit ...
18x8.5 +40 with 225/40/18 tires brings the wheel exactly to the fender
18x8.5+37 used on the front of IS300 .. the wheels sticks out of the fender ...
Old 04-24-03, 03:24 PM
rominl
exclusive matchup
rominl's Avatar
no, the wheel sticks out too much, that's the problem
Old 04-24-03, 04:04 PM
lil' IS300
lil' IS300's Avatar
Damn this sucks so much. I bought Manaray VR-5 Quest wheels...all 18x8.5 35+ offset and was told it would fir the IS. Stupid me never researched to find out if it wouldn't fit and just got them. I wish I knew as much as I did about performance parts as I did with wheels...
Anyway, at least I got an incredible deal on it. I'll make some badass profit from the wheels and get new ones that'll fit.
This time i'll get a staggard set up. What do you guys suggest? 18x7.5 in the front and 18x8.5 in the rear with a 45+ offset? That shouldn't be a problem right?
Oh, if anyone wants these wheels, PM me.
Old 04-24-03, 08:07 PM
rominl
exclusive matchup
rominl's Avatar
some useful info i got from is300.net
front
width | offset | tires range (width)
x7 = 40 and up 215-225
x7.5 = 42 and up 215-235
x8 = 43 and up 215-235
x8.5 = 45 and up 215-225
rear
x7.5 = 40 and up 215-235
x8 = 42 and up 215-245
x8.5 = 45 and up 225-265 (255-265 requires rolling or shaving lip)
x9 = 49 and up 235-275 (MAY require rolling or shaving lip)
x9.5 = 52 and up 245-285 (MAY require rolling or shaving lip, 285 may require more modification)
x10 = 45 and up 255-315(requires pulling fender)
should have all the info you need
fourcsan
IS - 1st Gen (2001-2005)
10-16-10 10:24 AM
Grazy
03-20-10 11:06 PM
Black IS30
08-31-04 12:34 AM
evolon5150
01-29-04 12:53 PM
jcboiz
04-01-02 01:29 PM
Quick Reply: URGENT - Will 18x8.5 wheels with 35+ offset fit the IS300??
