2005 RX 330 aftermarket wheel question
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/1600x900/img_20160308_wa0006_24950a891dd5b072a0ffce7389e0fdf6bf5bf587.jpg)
Hi all,
Just picked up a 2005 lexus rx330, beautiful 1 owner vehicle, panoramic roof with only 80k.
I have a set of 19" Kahn Cosworth wheels that were on my Infiniti G37 sedan. Expensive set of wheels, shipped in from England 2 years ago.
Rim specs-- 19 x 8.5, 35 offset
Tire - 245 or 255, 50/19
Will these rims for the Rx330?
I did run some numbers on a wheel offset calculator, showing 25.4mm (0.96") closer on inside.
Anyone ever tried fitting 19x8.5 et35 on a rx330 or rx350 2nd Gen?
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1130/imag2741_e47f1f10a4fd8dff809f21499de3e9adb367a994.jpg)
If they had same bolt pattern like 5-114.3, then you have to consider the center bore and find the correct hub centric ring.
Too close on inside is easy, H&R wheel spacers can fix that.
I installed 20mm spacer on my 13" RX450h for a few years and never have a problem.
You could use a 25mm to fix that, or 30mm to make it a little bit wider.
The wheels are 5x114.3 bolt pattern, will need a hub Centric for sure, hub bore is 75mm on the Cosworth wheels. Will be test fitting in the next couple weeks, will update this post for other members.
I am looking to put these wheels and tires in. Need help as if they will fit. The tires are 265/45/20.
And the rim is
9Jx20 ET40.5.
Any help and feedback would be appreciated.
And the rim is
9Jx20 ET40.5.
