will a 275 series tire fit on a 10.5" rim?
Old 05-17-03, 04:58 PM
ATLgs4
ATLgs4's Avatar
Default will a 275 series tire fit on a 10.5" rim?
specifically, will a 275/35/19 bridgestone so3 fit on a 10.5" wide rim or will that be stretching it? i hate the look when the tire is too big for the rim and it bulges out. if a 275 wont work, whats the optimal tire size for a 19x10.5 that corresponds to a 245/45/18? thanks.
Old 05-17-03, 05:19 PM
bravo261
bravo261's Avatar
285/30/19 sounds better
Old 05-17-03, 07:35 PM
TTurboPimp
TTurboPimp's Avatar
They will be stretched. I have 275's on a 10" wide wheel, and they are ever so slightly stretched, I wish I would have went with 285's on my 10 incher.
Old 05-18-03, 06:27 AM
cyclemax
cyclemax's Avatar
Default Re: will a 275 series tire fit on a 10.5" rim?
Do you hate the look when the tire is smaller than the wheel or larger than the wheel? I didn't know if you meant "stretching" it figuratively or literally. A 10.5" wheel is well within the approved range for that 275 tire, but it will look a bit "stretched" (literally). Some like this look, others don't. You can see a 275 tire on a 10.5 wheel here:
http://www.wheelexperts.com/wheelexp...thumbnails.asp
The diameter is about the same as you are using on the front, but you may want to consider the 285 if you can fit it, again, depending on your tastes. You also may want to match the sidewall look of your fronts, for uniformity.
Old 05-18-03, 09:12 AM
TTurboPimp
TTurboPimp's Avatar
By the way, I have the SO3's on my ride as well, the SO3's are a design that curves inward on the sidewalls, not a vertical sidewall like other brands. This curve will also make the tire appear more stretched. I had 285 P Zeros and thought I could go down and not look stretched at all. If I would have went with the 285 SO3's it would have been perfect.
Old 05-18-03, 06:09 PM
LS4fun
LS4fun's Avatar
What size tires front and rears do you have currenlty? You have 8.5 fronts and 10" wide in rears right?
Old 05-18-03, 07:57 PM
Received 2,345 Likes on 1,536 Posts
I am in the same boat and agree completely. Do you have ANY rubs on the back by the way? What springs/shocks are you running?
Old 05-19-03, 02:15 PM
TTurboPimp
TTurboPimp's Avatar
Yeah, those are the right widths. I have 245/35/20 F, 275/30/20 R....I used to have 255/35/20 F and 285/30/20 R.
My old set up rubbed like crazy, so I went down one size to fix the rubbing issue. But after buying a different brand tire, I could definitely have stayed with the wider sizes with running the SO3's, just due to the design of the sidewall.
Bit, no rubbing at all now. I have the Tein FLex, lowered pretty low, less than a finger of gap. I do have my fender wells trimmed, which I had done before with the wider tires and still rubbed.
Old 05-19-03, 03:59 PM
cyclemax
cyclemax's Avatar
TT:
What offset rear are you using?
Old 05-20-03, 09:01 AM
TTurboPimp
TTurboPimp's Avatar
+37 front, and I think +44 or +45 rear, I cant remember off hand on the rears. I know the front because I just checked them again trying to figure out what big brake kit will fit them.
Old 05-20-03, 03:14 PM
What kind of tires did you have before that rubbed?
I wish I had someone local who had Tein Flex - how do you think they compare to Tein HA's, any idea?
Old 05-20-03, 08:36 PM
TTurboPimp
TTurboPimp's Avatar
Bit, the Pireli P zeros.
The only coilovers I have had experience with on the GS is the Flex, so I dont have any input for you on the comparison to the HA.
mlor12
02-23-13 09:04 AM
mdgrwl
01-10-10 10:36 AM
PR FIEBRU
03-12-09 04:54 PM
05ES330
03-15-06 06:43 AM
CmputerWiz
07-01-02 11:33 AM
Quick Reply: will a 275 series tire fit on a 10.5" rim?
