Just put 20's on and im RUBBING! Need Help!
Old 06-08-03, 02:53 PM
BLu_Gs3
BLu_Gs3's Avatar
Exclamation Just put 20's on and im RUBBING! Need Help!
i got 255/35/20 khumo's on. The front driver side is rubbing everytime i make a sharp left turn. Im not sure but theres this bolt thats under the fender part of my suspension i guess. Its scraping against my tire. It made its own thread along with the rest of the threads on the tire. Any got an idea of how i can fix this problem?
Old 06-08-03, 03:34 PM
JacobT
Guest
Posts: n/a
You need at lease +38 offset to clear the upper control bolt for 20's. You have two choices now. Shave the bolt (* Not safe) or use a spacer (5mm) to clear the bolt
Old 06-08-03, 03:47 PM
bluelex
bluelex's Avatar
u probably got the wrong offset or too low of an offset, like J said, is the car lowered?
Old 06-08-03, 04:30 PM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
Depending on where you are in NY, I can send you to someone who may be able to help. He is in Brooklyn, in the Bedstuy section.
Old 06-08-03, 06:04 PM
J.P.
J.P.'s Avatar
https://www.clublexus.com/forums/sho...threadid=84366
bluelex - GS4Will spoke the truth, should have ran a 245.....
DoomLight
SC- 1st Gen (1992-2000)
13
09-20-11 05:06 AM
Tdvlexo
02-13-10 08:20 AM
ksmith
01-26-04 02:48 AM
TopSCecreT
07-25-03 11:22 AM
RIPP7399
07-08-03 11:41 AM
Quick Reply: Just put 20's on and im RUBBING! Need Help!
