00 LS400 bad rotors and breaks (help)
00 Lexus LS400
i have drilled and slotted rotors
when I breaks it squeaks a lot and when I get to a complete stop it sounds like if I’m breaking brick with brick.
Any recommendation on drilled and slotted rotors and breaks
The holes and slots shouldn't cause a squeal. If the rotors are severely glazed or have a deep lip, they will usually squeal. If the rotors look OK then it is more likely to be a pad issue. The type of pad you use has a LOT to do with brake performance, noise, dust, etc. They need to be quality pads and made of the right material for the rotors you're using.
00lexus1u
03-01-18 04:36 PM
iceman400
Suspension and Brakes
23
10-30-16 02:29 PM
