Would this fit my GS
Hi Guys
Can you tell me if this would fit my GS Nice ( have the chance of getting these)
20"x8.5 +38 all rouund ?
20"x8.5 +38 rear ?
20"x7.5 +37 rear ?
+38 on the rear & +37 on the front ?
what would look good I dont want them to rub the fenders (or any other part) but i also want them to look meaty ?
PS what tires ?
Thanks for any help guys
20"x8.5 +38 rear ?
20"x7.5 +37 rear ?
PS what tires ?
But will they sit out to far or even sit in to far and look stupid
What do you think will this look good ?
20"x8.5 +38 all round with 245/35 front and 275/30 rear but will it ever rub?
in chrome
Thanks for the advice
on thing i forgot to mention my car is a GS300 sport and it is lowed from Factory by 25mm will this be a problem
in chrome
One other thing is that at the end of the year i would like to change my GS for an LS430 or LS400Mrk4 depending on price will thess wheels fit my next or will i have to change them?
Thanks
Thanks
Sorry to keep aksing but after reading some other post some people mention the size of the lip on the wheel is this taken in to account when the offset is give or do have to deduct it from the offset
Thanks for any advice
https://www.clublexus.com/forums/sho...threadid=89724
Wheel width, offset and diameter are all factors of lip size.....diamter, only because depending on what brand of wheel you buy [custom or off the shelf] - Work, HRE, IForged, Kinesis [custom], or Enkei, Kruz, ADR, Axis [off the shelf]
OFFSET DEFINED
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside.
tomtsops
10-03-07 04:36 PM
CamRen
Wheels, Tires & Brakes Forum
12
04-27-02 04:34 AM
