20"x8.5 wheel 35 offset
will a 20"x 8.5 wheel with a 35 offset fit a 01 gs with a 1"to1.5" drop the offset is what i need to know if it will work if so what size tire should be used without any rubbing or modifying 245/35/20 or 255/35/20 will also be installing tein cs your input will be appreciated
NOT GETTING ANY INFO ON THIS OFFSET OR TIRE SIZE
Originally posted by JacobT
You should have no rubbing problem with 1.5 - 2" drop with 245/35/20. You may have some rubbing if you go with 275/30/20 at the rear.
Lakersfan
12-01-16 10:03 AM
ECUgs430
06-21-09 08:09 PM
CamRen
Wheels, Tires & Brakes Forum
12
04-27-02 04:34 AM
