Hub Centric Rings
go to a discount tire and tell them your name of wheels (they may have to take them off for fitment ) and your car and they will usually give them to you for free i have bought several wheels from discount tire and on my last pair i went to another location and they didnt look anything up just called wheel manufacter and gave them to me !
Are you looking for plastice rings or metal?
I was on ebay the other day looking for adapters and came on anodized aircraft aluminum rings around $25. the metal rings are the way to go because of less flexing in the materials. Just do a search under "Hubcentric", and you will find it.
I picked some up at Americas Tire. $5.39 including tax for a set of 4. They even had the application in their computer.
The part I picked up was
73-6006
Wheel Bore-73mm
Hub -60.06mm
Fits perfect.
Even with a real balance, I still get a slight vibration at 60 and 80 so I am going to go ahead and update the steering rack in accordance with the Lexus TSB that addresses vibration.
thanks
73-6006
Wheel Bore-73mm
Hub -60.06mm
Fits perfect.
thanks
Master Thread Closer!!
Got a question....Do I need hubcentric rings if my wheel was made for exclusively for 5x114.3 bolt pattern?
One seller told me that I only need the centering rings if the wheel is a multi-bolt pattern wheel...ie: 10 holes (5 for 5x114.3 and 5 for 5x100 bolt pattern).
Comments please.
Comments please.
Yes. You should never rely on the lug nuts to center the wheel. One-your placing the load of the wheel on your lug nuts, and Two- you will not get perfectly centered using only lugs nuts causing vibration. Always use centering rings. The difference is noticable,safer, and it allows the wheels to be installed much easier.
Lee
Lee
