They are here after three months wait...
#31
Originally posted by Lonely Toothbrush
Where are your wheels at G?
Originally posted by JacobT
I had +44 18x8.5 on the front before. It would rub the wheel well inside plastic liner when turning the steering wheel all the way to one side.
Bro, Im praying with you
I hated a lot a rub sound from my dad's E-class.. I just wished they won't rub
#34
Originally posted by gewe21
I know Eric, it's not fun... but for now other things still occupied my mind, like a job interview tomorrow and an exam on thursday... exam s**ks... I'd like college to be over soon...
#35
It's very minor rubbing, you don't even hear it. Just when you took the tire off, you could see where the trie scratch on the plastic.
My current solution is a set of 20's with +38 offset
Originally posted by Blackened
[JacobT, and your solution is? does spacer work?
I hated a lot a rub sound from my dad's E-class.. I just wished they won't rub [/B]
#38
Originally posted by Swifty
congrats on your wheels.
What disk size did you get? Did you get medium disk for front and low disk for back? Or did you go Low and Super Low?
Originally posted by 1SICKLEX
PICS!!!!!!!!!!!!!!!!!!!!
#39
The veilside car is using these wheel settings:
Golt Dish
19x9 +37
19x10 +37
So according to the calculations this is what will happen.
Front
The clearance from stut housing to the inside of the wheel will be 9mm LESS
The outside edge of the wheel will RETRACT in towards the body by 9mm
Rear
The clearance from stut housing to the inside of the wheel will be 14mm LESS
The outside edge of the wheel will RETRACT in towards the body by 14mm
So you can use a 9mm spacer up front if it rubs and a 14mm spacer if it rubs in the rear. I'd recommend the H&R Spacers. You main concern should be if it hits the caliper. The back of the wheel is very flat, so you have to be more exact in the fitment to clear the calipers.
Golt Dish
19x9 +37
19x10 +37
Front
Rear
#42
Hello,
I hope I'm wrong about the front clearance, as well!! If you use a 245/35-19 tire, it might work- my 255/35-20 is on 20x9 +36, and the tire is perhaps 4mm away from the suspension upright... this means you can go as high as +40 on a 20x9. Yikes!!
You've got 20x9 +44 and 20x10 +49 ?
Compared to the Veilside, the new front will be inboard 7mm
and the rear will be inboard 12mm- definitely no need to modify the fender in the rear.
What tires are you going to run? We want pictures !!!
-Bob
19x9 +37
19x10 +37
-Bob
#44
Hope everything will be ok, that way he'll be able to post the pics...
Tomorrow we'll go to Chicago, TerryTCL is willing to help with the spring install.... we'll try taking some pics and post them here ASAP....
Bob, Will, thanks a bunch.... finally he got a set of Dunlop SP Sport 9000.... c'mon Will, where's mine ? I'm getting twitchy here... j/k buddy....
