Confused....Camber kit or alignment kit..
O.C. Lucky Strike Fanatic
Hey guys,
I thought switching from 295's to 275 would make my car sit perfect. However I still have a little negative camber in which the upper part of the rear wheel is inside and I am getting wear from the inside.
Basically the 295's warped and changed my cars stock camber.
I was on tirerack and saw an alignment piece which looks like the one below for 27.00. The question is what should I do?
Would an alignment be able to fix my negative camber? Should I go with a camber kit? Or can I just use the eibach alignment pieces shown below? Thanks alot and sorry if I am confusing you.
Bryan
Bryan
your car is lowered, right? Ok if so, get a rear camber kit and have a quality repair shop install and do alingment. If done correctly, this should take care of rear inside tire wear. I'd like to see alingment specs before they alingment. I'll tell ya what's wrong. That's a thought, get an alingment check. Most Goodyears, Firestones, Ect...do this for free to try and get your business. Then post specs, I ll tell ya what you need for rear. :-)
Bryan
Former Sponsor
There is no reason that you should need a camber kit unless you have the vehicle lowered 1.5 inches or more. If you moved to a wider tire many times alignment problems that were already present will show themselves more with a wider tire and wheel. I would have your alignment checked.
khizr23
02-12-18 04:02 PM
